can this be done i have tryed making wet ground and bring it into daz
hi
i want to make wet ground or street with water reflection of them as they are walking and when i make the map its fine in blender
but when i bring it into daz its all black i am not sure what i maybe doing wrong i have moved lights around still everything on screen is black
but looks good in blender only please help
thank you for your time
  • Is the model UV Mapped? Are you setting up the materials in Daz Studio?
  • lilweeplilweep Posts: 2,873
    Define "make the map"
    Define "bring it into daz"
    If the map is a grayscale texture image map (e.g., for reflectivity/specular) that you painted in blender, then it will naturally correspond to some kind of mesh via a UV map, in this case I assume the mesh would be the ground or a decal or something.  I assume you also have that mesh in Daz Studio?
    If you described what you did and what you believe you were trying to achieve, it would help explain what you did wrong.
    Like, what exactly are you applying your map to in Daz? The same thing you applied it to in Blender? What is the map for? What does it do in blender and what does it look like in blender? what does it look like in Daz?
    https://www.daz3d.com/after-rain-2
  • The problem with your set-up is the thing I'm pointing at now.
    You should be able to see my finger the same way I can see what you're doing.
