Help fix ponytail bone
DarknessvaltierDarknessvaltier Posts: 7
edited December 2023 in Daz Studio Discussion
Someone can help me? i did that ponytail model, works fine with G8 base, but when i apply a morph, the tail bones not follow the head
Post edited by Darknessvaltier on
  • crosswindcrosswind Posts: 10,354
    You may try to zero the morph (you applied on the figure) in the hidden properties of the hair, or fix the morph on the hair by re-rigging the tail ( will be a bit cumbersome...). Or just directly parent the hair to the figure's head instead of fitting it to the figure.
     u mean did the hair like a prop?
    Yes, like a smart prop, because some conformed hair will bring you the above-mentioned issue, then you have to fix the full head morph and the rigging on the hair. So direct parenting is frequently used in such a case to avoid cumbersome fixing.
    PS: If you make this hair as a product, you better fix some morphs at least for the popular characters from Daz Originals...
    Post edited by crosswind on
