How to use Genesis 8 asset(more kinda script) on genesis 8.1
Hi there, I have a genesis 8 asset but it doesnot apply on genesis 8.1. The error says please select a genesis 8 model. It does work with genesis 8 though but is there any way to make it work on genesis 8.1?
  • felisfelis Posts: 6,578
    What kind of script is it? Is it something using UV maps?
    The UV maps are different, as there is an extra for G8.1.
  • crosswindcrosswind Posts: 10,343
    edited December 2023
    Pls clearly describe what asset it is ~~, a duf / dsa / dse file ?
    Meanwhile,  if the asset is to add a Wearable (not a Shell) , a Smart Prop.... you may simply try : Select your G8.1, go to menu - Edit - Figure - Scene Identification..., change Node Name from "Genesis8_1Female" to "Genesis8Female", change Compatibility Base from "/Genesis 8/Female8_1" to "/Genesis 8/Female", then load the asset to see if it works or not...
    Post edited by crosswind on
  • Also, deepnding on what it does, you may be able to aply it to a Genesis 8 figure and then move it (by refitting/reparenting or by saving and applying a preset) to the 8.1 figure.
  • Hi Sorry for not providing the full detail. The product is Breastacular for genesis 8. I am trying to use this product on genesis 8.1 but gives the error.
    Meipe, the author, made this product support G8.1 long time ago... Pls go to Renderotica to download the latest product pack...
  • aadarsh.satputeaadarsh.satpute Posts: 71
    hi I cant find it for G 8.1 can you please share a link for the product. Thank you.
    We do not allow links to Renderotica
    As Richard says, I can't ~~ You just go to Order History of your account on RE site to search and download it ...
  • Yes I searched his whole catalogue but cant find anything related to 8.1 specifically maybe I will just ask him or somewhere else. But a big thank you for the help.
