Render issues with Pudgy Corgi after upgrading to 4.22
MelonLord
I'm not sure why but after upgrading to 4.22, i'm unable to render any scene involving Pudgy Corgi (now deleted from daz). I've tried rendering some old scenes and all worked fine albeit a little slow, and i've even tried rendering with pudgy only and it rendered fine with all the fur! but when i add the figure+fur in some scenes, daz behaves abnormal. It either gives me a error (that render is already in use), or there's a blank render window, or it takes forever to render or by some miracle even if it renders, it just give me pudgy without its fur. I'm not sure what going on, either the asset has gone bad or 4.22 is causing problems and my bet is on latter.
https://www.daz3d.com/forums/discussion/515096/pudgy-the-corgi-crashed-my-ds/p1
Changed some parameters and now it's working! ありがとう❤️
Glad to hear it. What did you need to change?
Used this setting (thanks to Princessdawn3d) :
PR Interpolation Segment Length: 0.5
Additional PR Hairs Density (cm^2): 800
