Will there be a new updated Daz Installer for Poser /Pro 11?
Shield Wolf
in The Commons
Just got Poser Pro 11and the latest Daz Install manager from the DAZ web site DAZ3DIM ver 1.1.0.41 has no way to add as an application Poser Pro 11. It only goes up to Poser pro 2014. Does anyone know when an upodate for this product will be placed for general consumption?
Thanks,
Randy
For now just create a new isntance of an older version of Poser and set the path to Poser 11/Poser Pro 11 - as far as I ama ware that is working, though I don't have a Poser 11 version to test.
But the library of its PP2014, you can add it to the library poser pro11, right?
I'm in PP2014GD, but the library of some content from my previous poser (PP2012) follow me on PP2014
you can try it until things are resolved.
The path to the application is not used for content, just for plug-ins (like the DSON Importer).
The Add application screen does not permit you to add poser 11. It only goes up to pose Pro 2014. No Poser Pro 11. See the attached files. Thanks folksfor trying to help me. Much appreciated.......
Just pick the most recent version of the right bit depth.
But I have Poser Pro 2014 installed on the same machine. Won't that mess with this installation?
I am using the most current version of the "Install Manager" 1.1.0.41 this does not provide a selection for Poser Pro 11 as the above pictures show.
I can't test, but usually duplicate paths don't cause a major issue - things just get isntalled twice (which si what you want). For DSON Importer I think you could also use PP 2012 as the application and get the same result.
Hi All,
I selected as Richard suggested and besides pulling up poser and looking at the application is there a way to see if there is now the same content in both applications. I selected Poser Pro 2012 and gave the path for Poser 11. Then I deinstalled and reinstalled some items from the install manager. Where can I check in the directory strucure of Poser Pro 2014 and 11 to see if this content is now in both locations. Please forgive me I had head surgery (memory ain't to great) plus I am still a fairly new Poser user even though I have had POser Pro 2014 for awhile.
Thanks....
SW - RN
Content isn't the issue, just the DSON Importer plug-in.
Hi Richard,
I deleted my Poser Pro 2014 and left me with Poser Pro 11. I have to download and reinstall all my content now. Will let you know how it turns out.
SW
It looks like I am okay. I had to add the library back into my Poser pro 11. And so far it looks like things are there once again. But I am still checking things. Thanks all.
