Problem with photoshop 3d
Hi, all. I installed the program and everything went find except for something called photoshop 3d. I got a message that read
- Install Manager cannot find a required path. The package for "Photoshop 3D Bridge for DAZ Studio 4.8+ (Win 64-bit)" requires that the installed path for "Photoshop CC, CS6, CS5, CS4 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again. What does that mean?
You need to tell the install manager where on your computer you have installed one of those programs. It is for a bridge between the two. If you do not own one of them, you do not need it.
Just ignore that. The newer versions of Photoshop allow you to upload 3d objects into them. From the error it now wants to know where to find the program, but if you don't have Photoshop installed on your system, then this doesn't affect you.
