Error in Lypsync and timeline Daz 3D 4.22 does not work
Hello, I recently changed my setup from Intel to AMD when installing Daz 3D 4.22 32 and 64bits, I have been having problems using Lipsync. My timeline doesn't play correctly even though the audio is analyzed correctly by the plugin. There is a very large delay making it impossible to use. When installing the 32-bit beta version I can even use lipsync, but for the audio to be correctly synchronized with the expressions I need to change from 30 frames per second to 45 or 60 frames. However, when compiling the entire image sequence and joining it afterwards with the audio, everything becomes out of sync again. I don't know what's happening, I didn't have this problem before, Daz's timeline synchronization worked perfectly with the audio and the render sequence in after effects. I used Daz 3D 4.15 32/64 bits but there is no way to download it again and my machine is a Ryzen 7 7700x 32GB DDR5 ram and RX 6600 with 500GB m2
