UI for Carrara 3D Extensions or Plugins.
We can design UI for Carrara 3D Extensions using MCSketch Tool.
Building UI for Carrara 3D Extensions
  • HeadwaxHeadwax Posts: 10,562
    that looks pretty awesome I Samuel.
    Thank you; I wish we had more documentation for Carrara SDK.
  • rk66rk66 Posts: 450
    I believe in the sdk for Carrara 7 you can find more docs. But not sure.
     Thank you, it is good I was hoping for good detailed tutorials explaining all the functions of Carrara SDK library.
    Chap called Fenric used to be a mine of knowledge . Made plenty of pkugins. I wonder if he ever pops in
    @Fenric :)
  • RuudLRuudL Posts: 227
    I'm sorry to bring you a little bit of sad news. The docs (Overview.pdf and CookBook.pdf) in both SDKs are exactly the same.
    edited December 2023
    I too wish we had a better, more complete, documentation. However there are code snippets in the include files that will show you how to use it.
    Another way to access the SDK is by using the SDK Reference. But you'll have build it yourself (see my post in the Developer forum).
    Tip: Download all the sourcecode from the developers that went OpenSource (e.g. Inagoni, Digital Carvers Guild, ... ) and learn from their code.
    Post edited by RuudL on
    Thank you so much!
