Just want a little clarification on hidden items while rendering, please.
As I understand it, selecting visibility will hide the object from view, but IRAY still does a background rendering on it, as if it were still in the scene, correct?  In order to have IRAY completely skip rendering something, it just can't be there?
I seem to remember seeing that here, but can't find the thread.  Can anyone clarify if I need to actually delete the things I don't want rendered in order to save memory, or is toggling visibility good enough?
Thank you!
  • crosswindcrosswind Posts: 10,358
    edited December 2023
    Nope... if you click to Hide the object or node or turn off Visible in Renders,  there'll be no so-called "background rendering" for both geometry and texture of the hidden items.
    Wisely toggling Visibility would be good enough as you said.
    PS: You may simplly compare the VRAM consumption with GPU-Z - Memory Used, by toggling Visibility.
    Post edited by crosswind on
    Awesome thanks for the answer! I appreciate it
    You're welcome! yes
