Two files with textures
calaopiecalaopie Posts: 215
edited November 2015 in New Users
object has 2 files with textures, each texture is missing what is the other.
I can not impose a texture so that it fits. The texture is simply divided into two files. Is it possible the correct impose these textures?
1920 x 1080 - 353K
1920 x 1080 - 383K
Post edited by calaopie on
    What model is this, and what format is it in?
    If it is in OBJ format, it should be UV Mapped if it has textures with it.   Please explain a bit more fully what problems you are having
  • calaopiecalaopie Posts: 215
    I try
    I downloaded  contents of tf3dm. pz3 file format with file textures in TGA format. Load this plane on scen and I wanted to paste these textures on a plane but they are in 2 files.
    File and how should looks plane.
    1920 x 1080 - 428K
    1280 x 768 - 322K
  • Probably two alternative liveries, if you mean the two files labelled Body.
    that's what I mean.  It is the texture of whole plane split into two files, body and body 2
    1920 x 1080 - 353K
    1920 x 1080 - 383K
  • AJ2112AJ2112 Posts: 1,417
    Model is not compatible with DS.  Download Lockheed C130 Hercules, model is obj, with textures works fine in DS.  Import model into DS smiley
    It costs  100$. I'm looking  something free or costing not much.
  • BradCarstenBradCarsten Posts: 856
    Let me see if I've got this right- so the textures cover different parts of the plane- ie the one will cover the wings and the other the body etc? When you open them in Daz, and switch the textures, do they work- ie will the wings be textured, then you switch the texture and the body is now textured?
    Post edited by BradCarsten on
    exactly, first file  textured body, second textured wings. But never mind, downloaded this aircraft http://tf3dm.com/3d-model/c-130-38778.html and this works just fine.
    I just had to reduce the scale because the plane could not fit on the scene.
    Thanks to all for your help yes
    Here's the one I was referring to, which is free.  But cool, you discovered plane that works for you.
    http://tf3dm.com/3d-model/lockheed-c130-hercules-53871.html
    Post edited by AJ2112 on
  • It doesn't matter since you found an alternative, but it would have been possible to get around this by using the Geometry Editor tool to split the external body surface into two surfaces.
