Marcoor landing gear
Joe Webb
I'm a little dense so I'm not figuring out how the landing gear works on Marcoor FG C4.
When I select Landing Gear I get a control in Parameters labeled Other, opening that gives me a slider for Gear_up_down, from 0 to 1. But when I slide that it appears that only the parts labled Gear_R1 (and L1) are effected. The children of Gear_R1 move as attachements but do not rotate, so that landing pads, Gear_R3, end up at a 45 degree angle to the ground. I'm guessing that Gear_R2 is supposed to rotate as well, so that the landing pad ends up flat on the ground. Gear_R2 does not have pose controls in the side menu, and for whatever reason is difficult to grab in the onscreen pose controller (at least for me).
I was finally able to position them correctly but I there seems to be an issue with the Parameters.
Otherwise its a great little ship
