Daz Crashing while rendering some scenes
Hey folks,
I have a problem with my PC or DAz, i have a decent system with Nvidia 4090 watercooled and Intel 13900KF and 98GB ram 5200mhz and a few nvme drives ever since the latest update i try to render some images and my screen goes black and my pc restarts, no error after it restarts just a login screen,
Anyone else had a similar issue?
I rendered 20 images last night and no crash and rendered 1 today with a 1 crash.
thank you
Is there hair by Out of Touch, or other hair using Out Of Touch's shader, in the crashing scenes? Many of their products have been updated to address the issue, but it is a shared file so depending on instalaltion method and order it is possible to have an old version. You can fix it by seelcting the hair (all parts if it has more than one prop or figure) in the Scene, then selecting them in the editor tab of the Surfaces pane; type transm in the filter box at the top of the pane, you should see a transmitted Color proerpty - if it has a map applied click that to open an image picker menu and select None.
