Ultratree Creator problem
Steel RatSteel Rat Posts: 417
Just purchased this, installed via DIM.
When I try to start the script, I get a dialog error: "UltraTree Error: Selected Node not a tree".
Am I supposed to load a tree first? he PDF doesn't say to, just says start the script.
This is happening on two different machines, one running DS 4.15, the other 4.21. Exact same error.
Any ideas?
  • So I uninstalled and re-installed, it's running on the 4.15 machine, but not the 4.21. Both share the same runtime on a networked drive.
    Ultrascenery and everything else I have installed work fine, so why would this have a problem on one machine?
  • barbultbarbult Posts: 27,527
    You don't have to load anything before running the script.. It runs fine for me on 4.22.0.7 Public Build. You might try rebooting the computer that is having the problem and see if that resolves anything.
  • Moved to Technical Help as it is not a Daz Studio application topic.
