Genesis 3 not loading in Poser Pro 2014
I have Genesis 3 essentials installed in the external runtime I planned to use (in this case G3F) and I even installed it in the program directory runtime to no avail. I'm wondering if I'm forgetting something because I haven't installed a new figure in awhile. I did update DSON and install it as well, because even though I've had it installed, this is a newer poser install on a different drive (same drive as my runtimes). The figure will show up in DS, but not in Poser. I'm assuming it should be under "DAZ People" as other figures have always been and are showing up. Also note that the runtime folder under "figures" says the G3F file is empty, and I did refresh. I downloaded the files directly from my product library at DAZ and tried installing with both the DIM (which has it listed under installed) and after manually. I do notice that in G3F under Runtime/libraries/character there is no files when I look in explorer. The figure does show up in DS.
Am I missing something?
  • ByrdieByrdie Posts: 1,783
    edited November 2015
    Genesis 3 figures, and therefore V7 and M7, are not compatible with Poser. The Genesis and G2 figures will import via DSON importer, but even that will not get Genesis 3 into Poser. People have been trying, mind you, but so far with very limited success. The G3s use a system that Poser simply doesn't have, hence the reason DSON importer won't work on them.
    Post edited by Byrdie on
  • Thank you. I'm assuming this is still the issue with Poser 11 Pro?
  • prixatprixat Posts: 1,628
    Yes, still an issue. Poser 11 has the right kind of subdivision but no sign of UDIM or DQ support.
  • Thanks. Glad I didn't buy a bunch of G3 stuff before I knew that.
