v 4.22 - Create Advanced Iray Node Properties
How can I get updated script "Create Advanced Iray Node Properties"? According to video from Daz 3D  about the Ghost Lights in Daz Studio 4.22, my script is old because it does not show any dialog. In DAZ Install Manager I have only Default Resources for DAZ Studio 4.21+.
  • crosswindcrosswind Posts: 10,356
    Check the package date in DIM, the latest version of Default Resources is dated Oct 19, 2023. It is not, check your Ready to Download, download and install the update.
    1151 x 954 - 89K
  • Michal P.Michal P. Posts: 95
    edited December 2023
    Thank you for the avice. As I mentioned, I have Default Resources for DAZ Studio 4.21+. I also tried to uninstall and install again before I posted the previous post.
    Now I found that it is even more weird. When I run the script from the Content Library it runs some old script. When I right click and I choose Browse to File Location, it opens folder where the new sript is saved. When I open this script in the Script IDE in Daz Studio and run it, it works as new script (the dialog is showed).
    So the solution is to open the new script in the Script IDE in Daz Studio and run it from the IDE.
    295 x 364 - 23K
    689 x 259 - 30K
    247 x 94 - 7K
    Post edited by Michal P. on
    Yes it's weird, as I saw some other guys also encountered the similar issue... Did you ever install the old version of Default Resources with Daz Connect ?  If so, you should first uninstall it from Smart Content.  Don't logon Connect, then re-install Default Resources with DIM.
    If it's not the case of Daz Connect, you may first delete the product from your Content Library, completely extract the files from the IM installation package of Default Resources to your Daz Library, then re-import metadata.
    Yes, I used  Daz Connect in past.
    Yes, if you then updated with DIM, unintall the one installed with Daz Connect first. Don't logon to Connect, always use DIM then.
    ... refer to - https://www.daz3d.com/forums/discussion/657436/create-advanced-iray-node-properties-script-not-working-in-4-22
    Post edited by crosswind on
  • I found that it runs old script from this folder:
    C:\Users\username\Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_13176\Scripts\Utilities
    So I replaced it with new version.
    851 x 258 - 32K
    Not really recommended.... If you chose to use DIM, you shouldn't have kept a copy from Daz Connect... and Connect should be deactivated.
  • Updating the Connect isntall would have given you the new version, now that it is officially released.
