How do I make Zero Select Items warning go away? Public build 4.22.0.1
AliKat
I'm using the public version because the gen release is too unsable.
Is there a way to make that pop-up warning stop spamming me?
"Zero is often chosen when restore is the true intent"
Ok, great. Can I cancel out of this box with a cancel option or the X in the corner? Apparently not.
Post edited by AliKat on
For this feature, you either click Zero or Restore... and this dialogue cannot be removed, at least for now...
thanks
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/actions/action_trigger/start#example_with_settings is a sample script for triggering actions, which uses the Zero Figure command to demonstrate its working.
