Magix 101 hairs. thoughts?
I notice there are a number of these in the v4/m4 sale and I've had a few in my wishlist for ever, but I was just wondering how well these work nowdays with DS 4.8
Anyone have some experience with these and will relate the same to me. Thoughts? Raves? complaints?
  • EsemwyEsemwy Posts: 578
    Generally speaking, hair hasn't changed much. A good hair piece and material can still be quite usable. You'd probably have to play with the materials a bit to get them to look good in Iray, or there are some optimized shaders available for sale. You may also find that you need to parent the hair rather than auto-fit it to get it to keep it's shape properly. For that matter, some older hair are props rather than conforming items, but that won't keep you from using them productively.
    I don't know about Magix' hair products in particular, but you can always return anything that doesn't work out.
  • HorusRaHorusRa Posts: 1,665
    edited August 2017
    Well I have UHT hair shaders for Iray, but I'm curious about these hair in particular.
    Post edited by HorusRa on
  • Oso3DOso3D Posts: 15,115
    There are some basic ways to breathe a lot of life into old hairs.
    First, make sure to have at least subd 1 on the hair. Get some map of strands (black and white somewhat irregular striped pattern), tile it horizontally 16+ times in Displacement with -.1 to +.1 at about SubD: 4. Either use UHT or Unshaven 2 hair or experiment -- get rid of any diffuse or glossy colors. The key is to preserve the cutout.
    Even a hair helmet starts looking like real hair.
  • TaozTaoz Posts: 10,344
    edited November 2015
    If you mean how they work with IRay, there's a couple of quick samples here, using the default (3DL) textures (Sabrina / Evangelique) and then one (Savannah) using the UHT TN shader.
    1008 x 950 - 139K
    1008 x 950 - 139K
    1008 x 950 - 150K
    Post edited by Taoz on
    edited August 2017
    hey there. Thanks for the reply,  I purchased a few around 30 mins ago.  I just meant all the way around, just if they were quality hair and how they worked in 3dl and iray.
    edited August 2017
    Thanks. I was looking for some different info (read above) but your info is helpful on a different level. smiley Thanks.
    Heh, I wonder if 'Wear them all' would succeed in fitting these on G3F. I will have to try that. devil wink
    Yup. 'Wear Them All' comes through once again. Sabrina hair for V4 on Victoria 7. yay! I love that plug-in. Breathing new life into all kinds of items.
    1354 x 656 - 1016K
  • HorusRa said:
    Hello, this is your hair?
  • I'm trying to find Magix's Stahr Mayden Hair. Is it still on sale anywhere?
