Turboloader question
Choppski
in The Commons
If I used turboloader to remove all but a small set of morphs and expressions from a genesis 8 figure, what if I decide I want to add something I have removed. Do I have to reset the parameters and then reload the figure? Or, can I click on the character or the add body morph?
Turboloader comes with an interface that you run to switch on any morphs you want (it is a large list of products within which each morph can be viewed). After using it you then need to reload the figure.
You can also buy the Turboloader utilities and use this to switch on any morphs of a character you have created before and store as a duf file.
I think I have the utlities. I have seen that if I use the enable morphs and merge into scene with a character it does that. But for whatever reason, it's been really slow lately. with or without turboloader. Was thinking of really paring the gen8male down to only basics, but then creating new characters becomes tough.
Are you using the latest DS version?, ie 4.22, that significantly speeded up figure loading for me.
If you have a lot of expression packs, you might want to consider disabling those that you do not need.
Thank you for the suggestions. I am not yet using 4.22. But this is odd that it is so sudden. I will consider upgrading. And yes, I can try to remove the tons of expressions. LOL
Well not remove--disable them.
It could be that you have added a morph that is causing some conflicts, and this has suddenly slowed down the figure loading. The new version, I believe, is better at loading these types of issues.
