Packaging DAZ Studio product for distribution
Hello everyone
I have a problem with a motorcycle that I created for Dazstudio.
The motorcycle consists of two parts. Front wheel and rear wheel.
The front wheel is steerable.
Now I would like to save the motorcycle in save as support asset figure/props to share it with others.
unfortunately only the front part is secured.
How should I proceed to secure the entire motorcycle in props?
Thank you very much for your help Andreas
1827 x 1180 - 364K
  • crosswindcrosswind Posts: 10,358
    The standard way: you merge and rig front + back objects as a single Figure or Prop before saving as Figure / Prop asset, if you aim to make a "motocycle product".
    If it's just for a simple sharing with your friends,  you don't have to save it as any asset, saving as Subset or directly sharing duf scene file will be also fine. (plus texture files of course...)
  • Hello
    I guess I had the wrong approach. Will try with your first answer.
    thank you very much andreas
  • LeanaLeana Posts: 13,660
    edited November 2023
    IIRC you can save a "scene asset" if you want to save multiple new objects together.
    It should generate the technical "data" files and a .duf for each object, and also a .duf file which loads all those objects together.
    Post edited by Leana on
