Problem with Sun-Sky environment
Hello,
I observe strange behavior of sun in Sun-Sky Environment. It doesn't sets behind the horizon completely. On daytime it travels on the sky on arc (dependant or Longitude and Latitude) but as soon it gets to horizon it travels parallel to horizon (visible in half all the time) to the moment when it should rise ant then it rises and starts to travel on the proper daytime arc. The sun glow appears properly - it dims as it should, but the sun disc itsef doesn't hide. It's confusing as it's almost impossible to get proper sunset scenes. I have DS v. 4.22.0.1. I believe that it used to work correctly previously.
  • FishtalesFishtales Posts: 6,218
    You can get rid of the disk by setting the Sun Disk Scale to 0.00 but then you can't get the half/quarter disk if that is what you want.
  • edited November 2023
    Yes. At the end i've found out this to be the workaround, but it looks like some kind of bug. Well. Since I do static scenes only I'll have to post-work that to add smaller pieces of disk, but it's strange. Anyway - thank you :)
    Post edited by sikohr_2465a065c2 on
