Problem rotate view with a new shortcut key
Hi all, i want to assign the rotate view (default: Alt key ) to the middle mouse button it is possible ? or it's hardcoded ?
  • DiomedeDiomede Posts: 15,454
    Good question.  I don't know but I did not see a set of navigation options in the preferences : shortcuts area.  Will be following this thread to see if anyone else knows.
  • Bunyip02Bunyip02 Posts: 9,333
    Have not assigned any keys, but there is this at CarraraCafe - https://carraracafe.com/wp-content/wps-content/forum/625/1_carrara_8_shortcuts___1.2.pdf
  • CelluloCellulo Posts: 64
    edited November 2023
    I alreay have this pdf file but thanks for the link Bunyip02.
    I have made a test change a shorcut key by another key, exit carrara, but i don't know where the file is saved and i don't know the filename for the config file, this maybe help if i can found it, it the same problem with hexagon.
    Post edited by Cellulo on
  • RuudLRuudL Posts: 227
    On Windows the config file - 'Preferences.txt' - is located in <your user>\AppData\Roaming\DAZ 3D\Carrara 8.5\
    I don't think the solution is within Carrara. More likely in the mouse driver (eg button setting in case of Logitech device). Or in settings like 'Accessibility' of the OS.
    Post edited by RuudL on
  • rk66rk66 Posts: 450
    https://carraracafe.com/download/8518/?tmstv=1700429194
    That file is the updated file for the shortcuts in Carrara.
