Free Aiko 3 & V3 Carrara Procedural Skin Textures
evilproducerevilproducer Posts: 9,056
edited November 2015 in Carrara Discussion
This is a rework of my original Procedural Skin texture built on a V4. The original V4 thread is here:
http://www.daz3d.com/forums/discussion/46128/new-carrara-freebie-procedural-skin-shader/p1
This version is built using an Aiko 3 model as a base. I also used Carrara's hair system to create eyebrows and eyelashes. You can get the set for free, here:
http://www.sharecg.com/v/82693/view/7/Material-and-Shader/Carrara-A3-Procedural-Skin-Shaders
This is a procedural texture set, so the base skin can be used on any model, no matter the UVs, but since this is a multi-domain texture set, the different shaders that define different effects for different parts of the body need to match the UVs for that particular model.
There are three black and white image maps in this set. One is to define where the eyebrow hair grows, and the other two act as masks to soften the transitions between the nipple/torso shading domain, and the lips/face shading domain. The maps should be saved internally within the shaders, but I have included them in case anybody wants to edit them.
I have to put my Genesis 2 conversion on hold until I can get another computer that can use C8.5. If anybody else wishes to do a conversion and share it, that would be awesome!
1500 x 2000 - 926K
1500 x 2000 - 810K
    luv Aiko :D
  • chickenmanchickenman Posts: 1,202
    Thanks I may try toiying with it.
  • AeonicBAeonicB Posts: 166
    These look lovely!  A3 is my  favorite character, and Carrara is my favorite 3D program, so this is awesome.  Thanks a bunch! :)
    Cool!
    Looks like the A3 Shaders and dynamic hair eyebrows and eyelashes will work on V3 as well. I figured the skin shaders would, but I wasn't sure if the differences in the morphology of the mesh would bork the eyebrows.
    Here's a couple renders with A3 and V3 together. The first is no GI, and the second uses the Skylight and an hdri.
    1500 x 2000 - 1M
    1500 x 2000 - 1M
    thanks Evil!!!
  • DUDUDUDU Posts: 1,945
    The Generation 3 is my favorite for animations, many thanks for this Kevin !
  • DiomedeDiomede Posts: 15,463
    Thank you.  Very generous.
