Synchronizing multiple lights or emissive surfaces in a prop
I needed to create a 'modeling/shopping' prop - a three-fold lighted mirror (full length) - and it seems to have come out nicety (side mirrors angles can be changed, too).  It has a total of 13 light sources around the 3 segments of mirror (think of a brass ring around a translucent plastic cover with light underneath).  Attached image gives a better idea than I can describe.  (Not fully rendered but it makes the point.)  Right now, I have emissive surfaces on the sources.  I'd really like to synchronize all the emitters with one control, rather than having to adjust all 13 one by one - which is a royal pain.  Alternatively, would it be better to actually put a point light inside each little source assembly, and make a 'master light'?   I'm thinking that in some situations, these surfaces might provide a little extra fill light to help scenes -  but not if they're a royal PITA to configure.
587 x 628 - 499K
  • FishtalesFishtales Posts: 6,238
    Select them all and save them as a Light Preset for the mirror?
  • If you make the lights a single surface they will sahre the settings, although you will not then be able to adjust them separately. To use Point Lights, assuming you want them parented, uee a Wearable preset for the mirror.
  • crosswindcrosswind Posts: 10,356
    edited November 2023
    You also may create 12 Instances for a "source Bulb", arrange them by using Align plug-in. Then change the surface settings on the source Bulb, the other "bulbs" will follow... No need to use Point Light, Emissive lights are good enough.
    2024 x 1398 - 704K
    Post edited by crosswind on
  • Iray Light Manager PRO by V3Digitimes might help.
