VDB Inferno issue
WhiteFoxWhiteFox Posts: 94
Not sure if this has been addressed yet as I haven't been able to find any references in the forums.
 I've noticed an Issue with the VDB Inferno product where it causes the 'ground' to become darkened after loading. the said ground remains darkened after deleting the prop (doesn't matter which one I load from the set).
I've attempted everything I can think of to fix it but to no avail. I'm not having this issue with any other VDB items so I believe it might be a combo bug (i.e. combonation of this product and 4.22)
The only way I've found to get rid of the darkening is to create a compleatly new scene.
Any help with this is appreciated.
1921 x 1081 - 562K
1922 x 1081 - 322K
Post edited by WhiteFox on
  • FishtalesFishtales Posts: 6,244
    Maybe it is changing something in your Environment Tab.
    I've checked that out already. Even went as far as loading a new blank scene and saved the render settings (including the environment settings) as 'Default Render Settings' so I could load that after loading the prop but even that didnt work.
