PreT Girls Fringe Hair
PreT Girls Fringe Hair for Genesis 8 Female(s) | Daz 3D
ARTIST:
I can't ask the artist direcctly so I'm asking here.
Is there any way to make this without the multiple hair locks inn the back?
otherwise it's perfect for my needs.
I cant turn them off or remove them.
Thank you.
  • felisfelis Posts: 6,553
    I don't have it.
    Hiding the hairbands, should be fairly easy. I assume they have their own surface, and then by setting cutout-oppacity to 0, they will become invisible. If you want to keep those in the sides, you need to create a mask (white to keep, black to hide) that can be used in the cutout-oppacity channel.
    If the hair is rigged, the tassels might have their own bones, and if so they can be hidden in the scene tab (the eye icon), and will be hidden in the scene. But I doubt it is rigged.
    If the tassels have their own surface, you can make them invisible by setting cutout oppacity to 0.
    But I think the hair would look thin without the tassels.
    The best solution, would probably take the hair into a modeller and make a morph, to smoothing the tassels out so they more follow the rest of the hair. How easy/difficult that would be depends on how the hair is modelled. It looks like the tassels is modelled as seperate items, which would make it a little harder to get a smooth transition. But overall it also requires that you are somewhat familiar with a modeller (of choise).
