Problem with VO Lisa
WonderlandWonderland Posts: 7,137
edited November 2023 in The Commons
Does anyone have https://www.daz3d.com/vo-lisa-for-genesis-9 and can test if they have the same problems?
First of all, when I tried her one click expression, it brought up two Mousso expression dials that I don't believe are meant as merchant resources.
Second, when I clicked on an eye color, it removed all makeup and completely set the skin I had tweaked to default. The eye color should just change the eye color!
Anyone else have these problems? Probably returning it.
920 x 192 - 32K
Post edited by Wonderland on
  • GordigGordig Posts: 10,816
    Morphs don't need to be merchant resources to be included in another product, so long as the product containing the morphs is purchased separately rather than the morphs being included in the new product. It would be a bit strange to include another PA character's morphs in your own character (as opposed to, say Daz base morphs), but it's not strictly wrong. What IS wrong is that, if that is the case, the Mousso character isn't listed as required.
    edit: I'm still waking up, but I still recognize how poorly I worded that. A product can REFERENCE other morph products, textures etc., but can't include them unless they're merchant resources.
    Post edited by Gordig on
  • jd641jd641 Posts: 463
    Sorry, I know my post isn't going to help but I stay away from anything from this vendor, I had so many problems that never got fixed even after going back and forth with tech support. I returned the one character I bought from them moths ago and I'm still running into issues with scenes I haven't opened in a while asking for VO specific morphs that have infected my all my older G9 saved files like a virus.
    Post edited by jd641 on
    I'm wondering what would have happened if I hadn't already owned MSO Dola...
    Ugh. I have a bunch of their products I haven't tested...
    I wouldn't worry about it. I checked with a friend that has several (7) VO G9 characters (not Lisa) and he has no issues or preloaded morphs when he loads default G9
    There is no sign of those in the Filelist, which is aprt of the readme page (and you have access to the list of isntalled files through DIM/Daz Central, or can browse to the product folder by right-click on the product in DS to check) - there may be incorrect links, however, so it may be worth reporting this to support (I don't have the character to test).
  • crosswindcrosswind Posts: 10,343
    First time to try... a wrong definition in Vo Lisa Smile.duf file. Pls send a support request.. meanwhile you may delete these wrong coding lines...
    He made an expression but with other char's expression properties dialed, it was totally wrong...
    1092 x 1324 - 99K
    Post edited by crosswind on
    It doesn't necessarily mean there will be a problem with all their stuff, but others have had similar issue like mine with this specific vendor which is why I would not buy from them again. While it's not the same problem, this might actually be worse because it's referencing someone elses smile. o_O
    Yeah, really bizarre to have another PAs dials pulled up! I already have a bunch of this PAs products I haven't tested yet but I doubt I'll purchase much more in the future.
    I found a user on another forum that has VO Lisa and asked if they would test the issues you are having with Vo Lisa. He got the same reference to the Mousso smile, but there are also other default smile parameters loaded to add to it. Without the Mousso product, you still get a smile, but it's much more subtle. As for the eye/skin change, he darkened the skin to see if the eye change triggered any skin change and he had no issues with changing the eye color.
    If it is just a preset to another PAs expression, I personally don't have an issue with it, but then again it should be listed as a requirement if used. I have a few VO products with no issues using them, and other than the one issue with the Vo Mieko morph being at 100% all the time,  that was later fixed, I haven't really heard of any issues with this PAs products in the forums
    I didn't try all the eye colors but at least one of them removed all the skin tweaks I had done and LIE makeup. I got so pissed off, I'm returning it. Without the Mousso morphs, it's not even a smile, just puffy cheeks and a bit of squinty eyes. I have the Mousso character that's needed but it seems wrong to use another PA's morph, especially not listing it as a requirement. I don't trust the authencity of this PA anymore,
