Need help with 4.22
A scene that rendered in iray with no problem in 4.21 now won't render at all in 4.22. It goes through the process before rendering but then just cancels out on its own and then the whole program freezes. From the little experience I have with understanding logs, maybe it's not able to read certain assets (I thought it maybe because I changed the name of the figures in my scene so i changed it back and the problem persisted.) or illegal memory access (whatever that means). Here's my log file. Any help or advice will be welcomed. When I upgraded to Daz 4.22 I also checked and upgraded my Nvidia driver.
txt
txt
log.txt
283K
  • crosswindcrosswind Posts: 10,359
    You use a hair Linda Ponytail from outoftouch (OOT), first go to DIM to dowanload and install the latest update of the product. Press F2 in DS, clear DSON cache files. Reload Linda Ponytail hair and retry rendering.
    The 6GB VRAM on your RTX 2060 is quite restrictive.
    never gave me a problem as long as I keep the driver updated.
  • Princessdawn3dPrincessdawn3d Posts: 16
    edited November 2023
    I didn't do that exactly but watched a video about that. I disabled any textures in the transmitted color of the hair and when that didn't work. Thanks for the help though. I found my backup copy of the 2.21 install file. And just rolled back. I just wont update.
    Post edited by Princessdawn3d on
    Have you ever checked, how much VRAM the baseload from Windows, DS and the scene are taking?
    Download GPU-Z from https://www.techpowerup.com/gpuz/ and install
    Restart your computer, start GPU-Z, go to "Sensors"-tab and you can monitor the amount of VRAM used on the line "Memory Used"
    Start Daz Studio, create a primitive ball and render - How much VRAM is used?
    542 x 847 - 118K
