Resolved - Need help with finding morphs for Twist Hair
Worlds_EdgeWorlds_Edge Posts: 2,153
edited November 2023 in The Commons
Hi All, I know Twist hair (Twist Hair for Genesis 9 | Daz 3D)   comes with morphs but I can't find them under styles or poses or anywhere. I'm sure it is user error - any help is much appreciated.
Post edited by Worlds_Edge on
  • crosswindcrosswind Posts: 10,249
    Can you find them there in Params pane, as per the attached SS?
    502 x 1302 - 115K
    502 x 1302 - 108K
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    No. Under "actor," I only get "style" and "style all front" but nothing that says "poses."
    I deleted the hair from the scene and reloaded it. Now I don't even have an "actor" for the hair base in params. Very strange.
    In which way you installed this product... DIM or Connect?
    DIM.
    Worlds_Edge said:
    DIM.
    Check the Installed Files in DIM, see if the morph files (*.dsf) have been successfully installed and right locate in your Daz Library...
    1151 x 954 - 149K
    I uninstalled the hair again, and saw the updated 4.22 DS available in DIM. I went ahead and updated and reinstalled. Now I can see the hair poses. Thank you for showing me where they are/should be @crosswind. It helps not to have to bounce around from one panel to the next to try to find something that may or may not be missing!
