4.22 Question
Is it possible to roll back to an earlier version? My Daz crashes as soon as I switch between Iray and another shader :-S It just keeps trying to load in iRay in perpetuity in many of my scenes. If rolling back isn't an option is there a work around like installing a different driver or something? I do have the gaming version installed right now; would changing to the creator's version be any different? has someone encountered something similar to this?
regards,
Anti
  • LeanaLeana Posts: 13,553
    Earlier versions are not available for download anymore. If you have a backup of install files you can use that. You could also try contacting Daz support to see if they can provide you with a copy, but there's no guarantee at all.
    4.22 does require a more recent version of the driver than previous version, so if you don't have the latest drivers installed you should probably try that first.
  • Did you verify your GPU drivers on your pc yet to make sure you're using the latest version? They upgraded the Iray driver so I can't help wonder if this might be related. For what's it worth I'm having no issues with this myself.
  • TheKDTheKD Posts: 2,711
    You don't need the latest drivers to run it, 531.79 works fine with it in case you are also avoiding the "VRAM tweaks" that wrecks ML training lol
  • I found out that it is mainly one of my characters (Margot Robbie as Harley Quinn by Totocandy) which makes the window bug out :-/ problem is that I have 4 scenes connected with the character, so that blows hard, and every one of them freeze Daz when I try to switch to iRay in the render window. I have driver version 546.01; but it is the game driver, not the studio one. I might try to install the studio driver just to see if I can save the scenes. Thank you guys!
