Make the Filament drawstyle selector actually do something...
ShelLuser
Hi gang!
The issue
So, I'm one of the users who really enjoys working with Filament from time to time, it's actually one of my favorite render engines for quick results. If you check the customize pane (F3) you'll notice this option under the "Viewport DrawStyles" header and it even has a keyboard shortcut assigned to it.
The only problem: this option doesn't work, unlike all the others such as 'Texture Shaded', 'Wireframe' and even 'Iray' works as intended.
Suggestion
Fix the broken Filament option within the Viewport DrawStyles section so that we can finally use a toolbar button or a keyboard shortcut to switch to it. We can switch between all the other drawstyles except Filament and it seems odd to me that this option has been broken for so long.
Thanks for reading!
Bug reports should go to Daz via a support ticket, though starting a thread in Daz Studio Discussion (to which I am moving this thread) or Technical Help so you can get input on whether it is actually a bug before doing so is sensible. For what it is worth I see the same issue, though I don't have a default shortcut assigned.
