Daz Studio has encountered a fatal error, and must close.
akira1neoakira1neo Posts: 7
edited November 2023 in Daz Studio Discussion
DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\libiray.dll" at 0033:0000000050B6BBDB, mi_plugin_factory()+2658315 byte(s)
Please help me.
679 x 650 - 172K
Post edited by akira1neo on
  • crosswindcrosswind Posts: 10,249
    The errors are almost the same... do you also happen to have an OOT's hair in your scene ?
    Yeah OOT hair the reasson. How can I fix it?
    There's nothing wrong with OOT hair on my side. As per the exp. from others, select the hair, go to Surfaces pane, select Cap surface, check Transmitted Color slot, if there's a texture map, remove it (change to none), and test the preview or render.
    Then go to you Daz Library -: data\outoftouch\OOT Hairblending 2\, check the date of OOT Hairblending Hair.dsf and Cap.dsf... They should be mm/dd/2023 if you've installed the updated shaders from OOT. If not, update the hair in DIM.
    Post edited by crosswind on
  • This video explains in detail how to solve the problem in a simple way:
    https://www.youtube.com/watch?v=wHvY1BdD4yQ
  • I am having the same problem with 4.23.0.1. Yes, its cause is hair but the hair surfaces don't have any transmitted color. How can I fix this?
    So which hair is it?
    related I hope... when I get the dead daz message and save the data ... it says here is where you send it and that just goes the page where you can fill out a ticket ... is there any place like a mailbox to just sent the report?
    The crash reported dialogue? No, just save the zip and attach it to a ticket.
    My take is I have limited time and am way short of time to use all the content I have.
    Having to fill out a ticket in order to help them improve their product is a couple minutes I don't feel the need to spare. Give me a dead daz page and a box to upload the report to..  glad to help.
    It's in the catagory of if everytime I check the daily sales at DAZ I have to slog through 25 pages because daz doesn't want to only show my the wishlist stuff, I generally don't. Saves me time and money. And that seems so counter productive to their goal of getting me to buy stuff.
