Can I convert any Genesis clothing to Victoria 4 or Micheal 4?
Can I convert any Genesis clothing or hair to Victoria 4 or Micheal 4 or any previous generations?
  • Yes but not easy
     you need crossdresser by evilinnocence
    and have to save as a Poser companion file with geometry first
  • pwiecekpwiecek Posts: 1,598
    Crossdresser is free.
    You will need to purchase a M4 and V4 license. There are a couple of free licenses incuded so you can try it out before you purchase the paid ones.
    The Santa Baby Outfit converted quite well.
  • XyetztXyetzt Posts: 27,572
    Is there a way to convert genesis 2 or 3 clothing to genesis or v4 or m4?
  • To Geensis, yes I'm pretty sure there are G2 shapes for Genesis. Converting to M4/V4 is much harder as they are not weight-mapped figures, and so don't support AutoFit as destinations.
    One thing that may work, to get close is to have the M4/V4 shapes for the figure you want to go from and then load the clothing on its intended figure dial in the legacy shape and pose to match the legacy figure...then export the clothing, as obj.   Then use Morph Loader to create a 'fit morph' from that exported obj...
    NOT crossdresser. Maybe you can convert to genesis using DS, export and THEN use cross dresser.
