a valid postgresql cms connection could not be established
I removed it a few times Re-laying, the installation after uninstall in the install manager continued to repeat. However, it doesn't work out. Please help me
  • crosswindcrosswind Posts: 10,318
    edited October 2023
    Ensure a correct PostgreSQL installation first. Press F2 in DS, CMS Settings tab, check cms cluster path and port, and click Start / Stop to test the connection.
    729 x 637 - 30K
    Post edited by crosswind on
  • Assuming you mean you uninstalled and reinstalled PostgreSQL, that probably won't help - more likely it is a simple disc space issue, permission issue (especially if you wmant you had accessed the ContentCluster folder in trying to fix the issue), or security software issue.
