LAMH help
CASINC
ok here we go. I got wolf 2.0 because it is cool and i have never used LAMH before but i cant find the player or whatever it uses anywhere. it is installed with DIM but no plugins, panes/tabs or players can be found. i have had the issue before with measure metrics and have never got that installed either. LAMH is the free version so dont no if it is needed but i have no serial # for it in my accounts. spent a bit googling everything but my problem seems to be to simple for others to need help. any idea would be great. thanks.
Hello, are you sure you don't have a Window->Panes->Look at my Hair Pane ? If not, check the plugin list in About->Installed Plugins and see if it's listed there...
lmao you must have snuck into my computer and put that stuff there because I'm telling you it was not there before. I know this because this time when I loaded the wolf it loaded with the hair already on it. Either way you solved the problem. Thanks a lot!
