[solved] All my G8 caracters are Hobgoblins
LoofyLoofy Posts: 6
Hello,
I was working on a scène with an Hobgoblin alone. I tried to save it using Save as/support asset/Figure prop asset to see if it was more interresting than save as scene subset.
And now all my G8 caracters begin with the hobgoblin shape.
How can I fix it ?
Thanks for helping
Post edited by Loofy on
  • crosswindcrosswind Posts: 10,249
    edited October 2023
    It sounds like you've overwritten Genesis 8 base figure with Hobgoblin's morph dialed by using  Save as Figure / Prop asset.... so you didn't use your own Vendor and Product name in  saving dialogue, did you?
    Either -: Restore you figure first ( Ctrl Shift + F ) . File - Save as - Support Asset - Save Modified Assets... Then reload your G8 figure
    Or -: You press F2 in DS, clear DSON cache files first. Then re-install the products - 'Genesis 8 Starter Essentials' ,'Hobgoblin'. Then try again.
    Post edited by crosswind on
  • LoofyLoofy Posts: 6
    Thanks a lot; I will try the 2nd and 3rd , method, cause I tried the 1st by myself and it didn't work.
    I am not a vendor so I didn't take care of this part.
    The 3rd method works, not the second.
    Thank you very much Crosswind
    Great! No problem ~~
