Genesis 9 Skin Texture failure using 3delight
Brannick
So, I'm experimenting with the Genesis 9 figure and I'm using the 3Delight engine because the set I'm using only has light maps for it, not Iray. The issue is the skin texture renders out as a stark white on the Cairo character who is very much NOT white. Is this a glitch? Or can you just not use Gen 9 with 3Delight? Or are their 3Delight textures coming but not released yet?
Items used:
Cairo for Gen 9
Gensis 9 Starter Essentials and expansion
Rural Chateau III
Daz Studio does not have built-in tools for converting Iray materials to 3delight, so you get the default material. This may help https://www.daz3d.com/rssy-3delight-to-iray-converter , though I don't think it handles the PBR Skin shader. Alternatively theer is https://www.daz3d.com/rural-chateau-bundle-iray-addon , or you could manually set up Iray lighting
