Daz to Unreal plugin feature updates possible.... Yes or No
majesticcreations
I don't possess any knowledge in programming or coding. However, from a user's perspective, there's a tangible need for an improved and streamlined process in the Daz to Unreal plugin, especially when it comes to retargeting bones and ensuring compatibility between Daz and Unreal skeletons. Here's a well-thought-out suggestion that, if implemented, could significantly enhance user experience and efficiency. Also, I'd like to say that this would negate the need for a third-party rigging tool. :) I'm not sure if this has been discussed already but... please take this into consideration.
Suggestion for Improving the Daz to Unreal Plugin:
1. Automatic Bone Retargeting:
- Current Issue: Users often spend a significant amount of time manually retargeting bones, trying to match and correlate bone names between Daz and Unreal skeletons.
- Proposed Solution: Implement an automated bone-matching algorithm within the plugin that can recognize and map Daz bone names to their corresponding Unreal bone names.
- The algorithm could use a predefined dictionary of common bone name correspondences.
- It could also employ pattern recognition or string similarity techniques to suggest potential matches, even if names don't match exactly.
- Offer a visual interface where users can confirm or adjust the suggested matches.
2. On-the-Fly Skeleton Conversion:
- Current Issue: Daz characters need to be manually adjusted to fit the Unreal skeleton, a process that can be cumbersome.
- Proposed Solution: Allow the plugin to automatically prepare the Daz skeleton for the Unreal skeleton upon export:
- Rename the Daz skeleton bones to match the naming conventions used by the Unreal skeleton.
- Rig the Daz character to the Epic Games skeleton standard.
- Ensure weight painting and deformation are preserved accurately during this conversion to maintain the character's original appearance and movements.
3. User Interface Improvements:
- Visual Feedback: Provide users with a side-by-side view of the Daz and Unreal skeletons, highlighting any bones that couldn't be matched or need manual intervention.
- Bone Matching Wizard: Offer a step-by-step guide or wizard that assists users through the bone matching process, providing tips and visual cues.
4. Detailed Documentation and Tutorials:
- Alongside these improvements, offer detailed documentation that walks users through the enhanced conversion process.
- Provide video tutorials or demos showcasing the new features and illustrating how they can be leveraged for optimal results.
5. Regular Updates and Community Feedback:
- Ensure the plugin is updated regularly to accommodate changes or updates in both Daz and Unreal engines.
- Establish a feedback mechanism where users can report issues, suggest improvements, or share their retargeting setups for community benefit.
Implementing the above suggestions could significantly reduce the time users spend preparing Daz characters for use in Unreal, allowing for a smoother and more intuitive experience. While I may not know the intricacies of coding or programming, from a user's standpoint, such enhancements would be invaluable.
