How can I get back to my regular workspace
Hi,
   I'm helping a customer of mine. Here is a screen shot of what's happened to his workspace.
Can you tell me how to correct this and get his regular workspace back?
Cheerio   lululee
1920 x 1040 - 86K
  • felisfelis Posts: 6,566
    It looks like he updated while Daz Studio was still running. When closing Daz Studio it can take several minutes to close all processes.
    To solve, close Daz Studio and reinstall.
  • lululee1lululee1 Posts: 346
    Hi felis,
    Thanks so much for the valuable info.
    Cheerio
    lululee
  • Did it help? I would expect the whole thing to be white if it was the isntalaltion issue, as that corrupts the style file. You seem to have the "empty" colour set to white, and no Viewport or other pane in the central dock area, but the other panes look normal.
    Hi,
       After days of working with this problem, my customer still cannot get DS back up and running.
    He contacted tech support, but they just told him to uninstall and re-install.
    He has uninstalled and reinstalled at least 3 times. He has used both daz uninstall, uninstalled with Windows 10. installed through DIM, downloaded an new DIM everything shows up the same as the screen.
    Any help will truly be appreciated.
    Cheerio
    lululee
    Screen shot
    1920 x 1040 - 86K
    So, if it is not an installation problem, what would I have to do to get the Viewport or other pane in the central dock area to show up?
    Cheerio
    lululee
    What happens if you go Window > Workspace >  Select Layout and select a layout?
  • Or just open the Viewport from Window>Panes(Tabs) and drag it, by the top bar, to the top of the empty dock area - you should see a line of highlight colour when it is in the right place. Uninstalling/reinstalling won't touch settings.
  • crosswindcrosswind Posts: 10,343
    edited October 2023
    @lululee1,
    If your customer tried all the suggested ways in here but the issue still sustains, you may ask him to uninstall DS first, cut and past this folder: '%AppData%\DAZ 3D\Studio4\' to somewhere else on another disk. Then re-install DS and launch the program.
    If it still fails, plus: go to Windows Registry - HKEY_CURRENT_USER\SOFTWARE\DAZ\Studio4, back it up and delete. Then re-install DS and try again....
    Post edited by crosswind on
  • crosswind said:
    @lululee1,
    This is not a good idea, there is a risk of breaking  things.
    Hi,  I hope it is ok to post this here with the link. If it isn't, please remove.
    Here is what worked for my client.
     "It seems that there are files that are corrupted in the user folder and
    it causes this to happen.
    You need to remove those files.
        Here is 5 minute video that will show how to get to and remove these
    files.
    In This 5 minute video it show the person lost "Meta data" that quit
    showing up but it should be the same for your problem.
      It is important to READ THE TEXT on the page because he left out some
    steps in the video on how to get to the user files. Take it one step at
    a time."
    https://www.versluis.com/2020/04/how-to-completely-reset-daz-studio-and-install-manager/
    Everything is running now.
    I have a question.
    He backed up the "Data" file  shown in the attachment.
    Do I have to reinstall everything into the "data" folder or can I back up the new "data" folder so I have it , but put my original "data" folder
    back where it was?
    Cheerio
    lululee
    659 x 410 - 55K
  • I really don't think a full clear-out like that is advisable, even if Jay is doing it.
    If your content was installed through Daz central (which the paths look like) or DIM then it should be enough to reimport the emtadata, once you have the content diectories correctly set up (check that you can load through the Content Library>Daz Studio Formats and Poser Formats).
    edited October 2023
    Richard Haseltine said:
    crosswind said:
    @lululee1,
    In fact there's nothing broken. It's just like a reset to the situation / status that one has never installed DS. And there're also backups...
    Lots of my subscribers resolved the similar issues in this way and we've even written a program to clear them all + residuals.
    edited October 2023
    I have a question.
    back where it was?
    Cheerio
    lululee
    Jay used the same way as I suggested. No need to back up data folder unless you've modified files there...
