Sniper Glint
JediKnight2140JediKnight2140 Posts: 38
Is there a way to add a glint, like the one you would see from a sniper scope?
Post edited by JediKnight2140 on
  • crosswindcrosswind Posts: 10,272
    A glint on the surface?
    Yeah. like something you would see in COD when someone scopes in on you.
    edited October 2023
    If they're like the ones in the pic down below, I'll definitely go for a post work after rendering, by using some brushes in Ps.  There seems to be some VDB props in some products.. but not sure if there's any 'glint' prop which could be used in the scene.
    1299 x 764 - 992K
    Post edited by crosswind on
  • That is unphysical, unless there is a bright light on your camera - a real glint would the sun or other source being at the right angle that when it hit the lens and bounced off it travelled to your eye (or the camera in this case) - which would be if it was coming from you, since the scope would be flat on, or close to allowing for the possible curve of the front of the lens.
