Crash when adding collision item...
Hi all,
I get a strange issue this morning : i add smoothing modifier to a armchair. When trying to add collision item to it (character) Daz Studio crash...
Do it means that it's not possibe to add smoothong modifier to ALL props ?
Thanks a lot
  • crosswindcrosswind Posts: 10,356
    Possible but depends on the props in some cases... Though I've never experienced a similar crash, suggest you check the topology / resolution level etc. of the prop before add smoothing modifier and collision item... better case by case.
    BTW, if you wanna add collision effect in b/t a Genesis figure and a prop, the best way is to add dForce modifier / weight node to the prop then simulate with the timeline.
    I've tried some things that simply don't have enough geometry, so the smoothing modifier actually breaks the prop (G8F sitting on a cushion, for example)
    But haven't had it crash yet.
    Like crosswind says, check the mesh resolution area in the parameters pane. Too high of a level on either or both items may cause a memory overload or somesuch - crash!
