IPC Between Daz Script and Mono.net Console App
Hello All,
I was wondering if there was a decent IPC solution that could be used with a Daz Script. I'm currently writing geometry to files and then parsing those inside a Mono console app, but it's a pretty slow way of consuming a large amount of data. Mono doesn't support named pipes, which would be ideal, but I'm wondering if there's a simpler solution I'm overlooking.
I've considered building a socket server into the console app and sending data as network requests, but I need to be able to send a response back to Daz. I'm not great with C++, so I'm hoping to figure this out with scripts, though I concede that may not be possible.
Edit: I should point out I've experimented with Standard Input and Output, but I've run into a lot of sync issues. I'm not sure if it's the way Mono writes to StdOut, but events aren't being reliably triggered and I end up with incomplete strings back in Daz. If this is the only solution, I'm open to making it work, but hoping for something else.
Thoughts?
Pretty sure you want to consume the
DzProcessclass. Check http://www.daz3d.com/forums/discussion/comment/833324 for a discussion and example as to how to get that working.I've done it successfully consuming a command line app, so I should be able to assist somewhat if you get stuck.
Thanks for the response, djigneo! Agreed, that looks like the best bet. Did you use Standard in/out to pass data? At a glance, something like this?:
var process = new DzProcess(appPath);process.canReadLineStdout (true);connect( process, "readyReadStdout()", stdOut);process.start();while (process.running){//Wait Around}function stdOut(){print(process.readStdout());}Edited: Also, does this method allow for writing back to Standard Input, or are the command arguments the only way to pass data to the console app?From a glance at the
DzProcessobject, it didn't seem like there was an obvious way to pass information other than viaDzProcess.arguments.My code populates DzProcess.arguments, but maybe try a few things out based on what you can see from the above code snippet. There does appear to be some StdIn things, but I'm unclear how to use them. Maybe an expert will poke in and help us out there.
I ended up with something like this for the actual process execution. The
processEvents()call is pretty important, as is waiting for the process to complete (so the script doesn't terminate prematurely).Thanks for the example, very helpful :-D There is a "writeToStdin" method, but I haven't had much luck with it. I'll keep tinkering, but it looks like this is going to be the best bet (though I may keep poking around for alternatives, just in case :-)).
I would recommend getting the basics working by passing arguments in. It took me a lot of fiddling to get it to work at all, so I would get proof of life before crossing any avenues off the list. Some of the things that should be really easy in DAZ Script take me a very long time to get right.
Quick update: Just had a small success! process.writeToStdin("Hello Console App") writes characters to StDout, but not lines. Adding a carriage return, process.writeToStdin("Hello Console App \n") registers the entry as a line, which the console app can read with Console.ReadLine()!
That seems like it might resolve the sync issues I mentioned (where I would get only portions of a string). Also, thank you again for the example, the timer was critical. I didn't realize that, by default, Daz Script terminates the app once the event queue is cleared. Adding the timer gave the console app enough time to do it's thing. Woot! :-)
Sweet! Good to hear you got it working. What's your project doing, if you don't mind sharing?
Nope, I don't mind :-D I've got a home-grown softbody physics engine I've been working on for a while. I've been on the lookout for a good platform to integrate it with. Starting with Daz. If it goes well, I may attempt a Blender integration as well (it's different enough from Blender's existing physics sims to maybe justify the effort). I've got it working at the moment using file inputs/outputs, but it requires geometry information for every phsyics step. It takes longer to write and read those files than to run the actual simulation! :-P That's why the ICP is so critical. If I can't make it work via script, I'll have to come up with a server/client setup with the Daz SDK, which would take loads more time than I have to invest at the moment.
Hi simtenero. Did you finally make it work? If so could you share the communication code for .net and daz?
Thanks!
Hey Flashmoyo, I'm sorry I didn't see this sooner, hopefully this is still of some use to you :-)
On the Daz side, it looks like:
And in a .Net console app, something like this:
You have to be careful of the length of your strings. Line breaks from Daz won't translate as line breaks in .Net, so you need to create some custom notation to check that you are done recieving a line before your request the next line from the script. If you don't, the console app or script can get ahead of itself and try to read a line that isn't there yet.
Hope that helps!
