DA big ocean
Philippi_ChildPhilippi_Child Posts: 680
edited October 2023 in The Commons
If anyone has this product:
https://www.daz3d.com/da-big-ocean
Can someone please point me to some reference material that shows you how to use it. I can't figure out it how this product is supposed to work. Thanks
Post edited by Philippi_Child on
  • AgitatedRiotAgitatedRiot Posts: 4,766
    Set the Ground Render Visibility See image below
    102 x 150 - 8K
  • Thanks but I've done this. My issue is when select big ocean plain and then apply a shader it doesn't change the plain at all. Still looks like the default texture. The only thing I could understand how to use some of the decals. By holding down the "ALT" key and dragging into the scene. I can't figure out how to apply the shaders to the sea plain.
  • barbultbarbult Posts: 27,499
    A quick Google search turned up this thread, but most of the search results look like pirate sites, so be careful.
    Select DA Big Ocean Plane, Go to Surfaces, Select The Plane, and then use the shaders. See image.
    1919 x 1032 - 690K
    edited October 2023
    See the Image below for what it should look like.
    1667 x 1667 - 2M
    1667 x 1667 - 3M
    Post edited by AgitatedRiot on
