How to export only the neck and head of Genesis 3? [Question]
Hi, I need to export only the neck and head of "Genesis 3" in FBX format, is there any way? Could anyone tell me? Thank you.
  • VenerisVeneris Posts: 115
    edited June 2016
    Somebody could help me?
    Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 111,841
    Please don't bump. I'm not aware that you can do this, the geometry belongs to the figure so you may need to reduce the model using the Geometry Editor tool in DS or in the destination application, taking care to make sure that the morphs have not been broken if you use any.
  • mikael-aronssonmikael-aronsson Posts: 607
    edited June 2016
    You could make all the body surfaces tranparent and set the specularity to zero maybe (will not remove it but at least make it invisible), depends a little on what you want to use it for if that would work.
    Post edited by mikael-aronsson on
  • Jim_1831252Jim_1831252 Posts: 728
    edited June 2016
    If you hide everything but the neck and head you can use the "no hidden" when exporting. I'm not sure of a quick way to hide all the geometry so I usually just hide the torso and manually delete the rest when importing to Lightwave (or whatever).
    Post edited by Jim_1831252 on
