DAZ Install Manager flagged as ransomware
MalwareBytes flags DIM as ransomware and quarantines it. This happens while I try to install any new modules today. DIM has been fine before today. I'm running on Windows 11. If I tell MalwareBytes to restore the file, it does. But the next time I try and install in DIM MalwareBytes flags again.
I could tell MalwareBytes to trust DIM, but since this hasn't happened before today, it seems better to investigate more.
I'm running Install Manager 1.4.1.67.
  • ShelLuserShelLuser Posts: 749
    False positives happen with some virus scanners. Even so, this is still an issue with the virus scanner; maybe you could report it to them or.. consider using something that doesn't mess up ;)
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,845
    in the past Malwarebytes kept doing that to Carrara, irfanview and Octane render
    I had to restore them and change the settings to allow them
    I think it killed one of my external drives too quaranteening the driver but have not been able to fix it and can no longer use that hard drive
  • MWB also does it with Daz Connect when updating - it iss eeing the repalcement of oen file with another and taking it as an attempt to encrypt the user files as a prelude to a ransom demand. Security applications really need to be more clear about whether they have detected actual malicious action or just soemthing that might or might not be malicious - these overzealous actions servce only to undermine confidence in the tools (and it isn't just MWB) and make it more likely that a real heuiristic detection of a new piece of malware will be ignored.
  • I added the following two programs to my Malwarebytes Allow List. MWB treats these as safe, and now I can install my assets through DIM.
    • DAZ3DIM.exe
    • DAZ3DIMHelper.exe
