How do I get out of UV View?
edited October 2023 in The Commons
This discussion was created from comments split from: Any hints for using UV View?.
  • I accidently clicked on "UV View" in the "Perspective view, front view, left view, etc." menu and I can't get back again. All I have is a blank gray screen. How do I exit UV View?
  • Split to its own thread.
    There should be a button at top-left labelled UV View that will give a drop-down-list of Drawmodes (the UV view effectively docks the viewport controls even if you don't usually use that mode).
  • crosswindcrosswind Posts: 10,249
    Simply press Ctrl + P...
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,507
    I remember when I first did this wink
    fullscreen is f11 key if you ever fall down that rabbit hole too
  • None of this is working. I do not see any button in the top left corner that says UV View, and Ctrl + P does nothing.
  • felisfelis Posts: 6,502
    Try to attach a screen shot.
    My bad... check and configure in here by pressing F3 in DS....
    931 x 779 - 63K
