Unhidden attribute stays hidden
Hi,
I check right now a new cloth product and see that the Expand All slider is hidden and even if the Hidden checkbox isn't enabled, I can't see it.
I have the same result for a PBM controller, it is useful, but it is only visible if I enable "show hidden".
So why does the Daz studio hide parameters/morphs even if they aren't set to hidden?
333 x 135 - 13K
  • Is this an item fitted to another? All proeprties on a fitted item that match proeprties on the base figure will be hidden, regardless of their settings.
  • LoonyLoony Posts: 1,817
    Yes, it's a underpant which is fitted.
  • crosswindcrosswind Posts: 10,359
    In DS, if a property on a fitted wearable is set as Auto Follow and there's a property on its 'Fit to' parent has the very same Name (not Label) as the former, the former will be hidden.
    The ways of showing it is either to uncheck Auto Follow or deactivate / delete the property with the same on the parent...
    Thank you, that's a bad thing, but well I can't change it, but now understand why.
