Where is my background ?
Hi all,
I've bought the following environnement file : https://www.daz3d.com/georgetown-apartment.
In the description view i can see background with sky scrappers throught the windows, but it doesn't appears in my scene : is it normal and how is it possible to add a same background ?
Thanks a lot
  • AscaniaAscania Posts: 1,856
    You find the same stock image on the Internet and add it as a backdrop to your scene.
  • ShelLuserShelLuser Posts: 749
    This is indeed quite normal, as mentioned on the product page it's an interior set so the emphasis is on the room and not the backdrop.
    Either use a backdrop (as Ascania said); you can use the "Environment" pane for this. OR... you can also use a so called "Environment map" if you're rendering with Iray: see the "environment options node" for this (it should be part of your scene).
    Hope this can help!
