180 S-Shape based Ornamental Wrought Iron Patterns ( maps )
the download and instruction pages
https://sites.google.com/site/mcasualsdazscripts6/mcjs_shapes_typea
and if you just want the zip and dont want no instructions!!!
direct link to the 16MB Zip
Introduction
I created some S Shaped animation paths using the Daz Script script shown below
then i used mcjTransport to create tubes that follow those paths
then i rendered them as 180 800x800 pixels PNGs
and that's what you get here !
Post edited by mCasual on
Warning : for nerd eyes only
Here is the script i used to create the animated paths that were
then used by mcjTransport to create the tubes ( morphs actually )
The line that reads "var step = 34 .... " is what sets the animation pattern
i used values 0 to 180 but there's probably interesting shapes to find using fractions
As you can see, it's the object ( usually a null node ) named Spline that will be animated
so you need something labeled Spline in your scene
The animation path duration is set to 720 frames
each tube section is 1 cm long
