Autofit disappeared??
So I have been using Daz a while and I accidentally switched directories, so I got all my stuff back, but now when I try to fit for instance G8 female to male, the dialog box opens but instead of saying Genesis 8 female Genesis 3 Genesis 2 and Genesis now it says unsupported and thats it. like I can't get it to bring it up. and certain items, like the pro skate cap no longer have options to turn them around even on the female head they're made for, is there something in options I need to reset or do I reinstall?
  • crosswindcrosswind Posts: 10,356
    What do you mean fitting a G8F to G8M, Genesis figures or Wearable?
  • Wearable, such as the Tenebris top, before this I could just click to add it to a male and it would ask and I would be able to select from the drop down menu "Genesis 8 Female" Now it only says "Unsupported"
    So you could not see those Clones from the dropdown list? You must've ever installed Clones products but they're gone after you modified your Content Directroy settings?
    1492 x 1275 - 484K
    Autofit uses metadata => Necessary metadata is missing.
    That's independent of metadata... The value of Preferred Base is defined in Wearable's *.dsf file. Auto-Fit plugin will detect it and show the dialogue box if Wearable's Preferred Base is different from the selected figure.
    As long as the required clone files could be found in data folder, you'll see the clones in the dropdown list.
    When Autofit was asking for which character a piece of clothing was designed for, G8M was missing from the list, but refreshing metadata got it there - Nothing else was done or needed to be done.
    edited September 2023
    Just simply test like this -:
    You move out the the subfolder 'Clones' from -: Your Daz Library\data\DAZ 3D\Genesis 9\Base\Morphs\Daz 3D. Load G9 into the scene, then load a garment of any Genesis prior to G9, no matter it has metadata or not. Then check the dropdown list in Auto-fit dialogue box...
    The mechanics is that dropdown list shows the Clones rather than any metadata...
    Post edited by crosswind on
