Hair missing in reflection
chris-2599934chris-2599934 Posts: 1,917
Here's a weird one. I have a lady looking out of a window. Everything is reflected in the window glass except her hair. Any clues as to how I fix this?
Post edited by Chohole on
    Which renderer?
    If it is 3Delight, what is the max raytrace depth set to, in the Render Settings?
  • chris-2599934chris-2599934 Posts: 1,917
    edited October 2015
    It's 3Delight, and it's 3. I'll try increasing it, but I don't see why the hair would need an extra bounce over everything else.
    [ADDED] I've doubled the raytraces to six, but it makes no difference.
    Post edited by chris-2599934 on
  • pwiecekpwiecek Posts: 1,598
    The hair has layered trans maps
    That doesn't really help me. Does that mean that it cam't be reflected? Or is there something special I need to do?
    Next question...what kind of lighting are you using?
    By the way, which hair is it?  What shader is being used on the hair?
  • Advanced Ambient, distant and spotlights. Marisandra hair. No special shaders.
  • I just tried putting the same hair on a G2F, lighting her with a normal Daz distant light, and sticking her in front of a plane with reflection added. It has the same problem:
    It's probably this "layered transmaps" thing that pwiecek said - but what do I do about it?
    edited October 2015
    Check that the hair isn't loading the omnifreaker UberSurface shader...as it has a couple of settings that can do odd things if you aren't expecting them to be on.  But in a quick test the UberSurface with Raytrace OFF renders a bald G3F...
    400 x 400 - 153K
    Post edited by mjc1016 on
  • Found a fix!
    In the materials for the hair there's one called "Raytrace Visible". Click that, and it works.
    For future reference, though, how would I know if an object is "loading the omnifreaker UberSurface shader" and which settings would I tweak? I didn't see anything obvious in the Surfaces tab.
    edited October 2015
    In the Surfaces tab...
    UberSurface: omUberSurface
    AoA SubSurface: AoA_Subsurface
    349 x 323 - 16K
    edited October 2015
     I was just answering this question, not offering a solution.
    Post edited by pwiecek on
